T_Y_
May 11, 2022Tutor
My R6120(AC1200) never to work with W53 channels (52,56,60,64) actually, but W52 or W56 in place.
I have two of R6120-100JPS (AC1200). Both of my R6120s never work with W53 channels (52,56,60,64) actually, but W52 or W56 channels in place as far as seeing status of connected WiFi STA devices a...
T_Y_
May 11, 2022Tutor
Hi, plemans.
Thanks a lot.
No WiFi AP working with W53 channels is around here as far as seeing the scan result of WiFi Analyzer app..
So, a DFS rader must be the most possible reason, as you mentioned.
However, as far as seeing DFS rader location on google map, the nearest DFS rader is 32km away from here.
Does a DFS rader affect or cover such a wide range?
Otherwise, does an informal DFS rader exist around here ?
T_Y_
May 11, 2022Tutor
Thanks, plemans.
OK, I understood. You are right.
Approx. 5km away from US Army base with air port...
So, a DFS rader, unregistered on google map, must be in the base.
- plemansMay 11, 2022Guru - Experienced User
Fairly likely. Because it includes military radar, weather radar, and satellite communication.
