Urvang
Apr 28, 2023Aspirant
My R6400v2 has stopped broadcasting the Wireless Network (5GHz a/n/ac)
My R6400v2 has stopped broadcasting the Wireless Network (5GHz a/n/ac) on all my capable devices. My router is running with the latest Firmware Version V1.0.4.128_10.0.104 and all required settings a...
michaelkenward
Apr 28, 2023Guru - Experienced User
Urvang wrote:
However, 5GHz network is working fine with the LAN cable.
LAN cables have nothing to do with WiFi. WiFi = wireless. LAN = wired.
Is the router setup to broadcast the 5GHz SSID?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Specify Basic WiFi Settings.
Router Firmware Version is V1.0.4.128_10.0.104. This is the latest version what I have checked on the Netgear site.
Have you tried a reset on the router?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Urvang
May 01, 2023Aspirant
Yes, 5GHz SSID Setup is already there.. Also reset my router twice but I can't see 5GHz SSID in any of the device.
- michaelkenwardMay 01, 2023Guru - Experienced User
I don't follow:
How can you know that the 5GHz SSID is "already there" if none of your devices can see it?
- UrvangMay 01, 2023Aspirant
I have checked router configuration and it is there
