Urvang
Apr 28, 2023Aspirant
My R6400v2 has stopped broadcasting the Wireless Network (5GHz a/n/ac)
My R6400v2 has stopped broadcasting the Wireless Network (5GHz a/n/ac) on all my capable devices. My router is running with the latest Firmware Version V1.0.4.128_10.0.104 and all required settings a...
michaelkenward
May 01, 2023Guru - Experienced User
I don't follow:
Urvang wrote:
Yes, 5GHz SSID Setup is already there.. Also reset my router twice but I can't see 5GHz SSID in any of the device.
How can you know that the 5GHz SSID is "already there" if none of your devices can see it?
Urvang
May 01, 2023Aspirant
I have checked router configuration and it is there
