WhyImHere
Jun 29, 2021Aspirant
My router is very unstable, keeps going off internet and stuck it
[remote login] from source fe80::c1af:763d:ab2a:80ee, Tuesday, June 29,2021 18:51:22 [DHCP IP: (192.168.1.6)] to MAC address 3E:7A:67:78:89:F5, Tuesday, June 29,2021 18:37:01 [DoS attack: RST Scan]...
michaelkenward
Jul 01, 2021Guru - Experienced User
Interesting as that log may be, my problem is the subject of your message and the details in your footer.
You say:
"My router is very unstable..."
But your footer lists the CM400. That is a cable modem. No router in sight.
So which Netgear router do you own? And what does "very unstable" mean?
You lose the Internet connection. The wifi dies? Something else?
- WhyImHereJul 01, 2021AspirantSorry I thought I put my R6230 on it, I’m using R6230+CM400, I check the connectivity on modem is good, but lost internet connection couple of time everyday. no matter how I rest it, it still come back.
- michaelkenwardJul 01, 2021Guru - Experienced User
WhyImHere wrote:
Sorry I thought I put my R6230 on it, I’m using R6230+CM400, I check the connectivity on modem is good, but lost internet connection couple of time everyday. no matter how I rest it, it still come back.You did. I missed it.
When you say "lost internet connection" what do the LEDs on the router look like at the time?
Does everything go off? Wired and wireless?
Have you tried disabling QoS, traffic metering and anything else that could strain the router's processor?
- WhyImHereJul 01, 2021AspirantI did these steps, but strangely the lights stay normal.
