jenandzack's avatar
jenandzack
Follower
Apr 30, 2017
My Samsung Blueray player keeps "updating system time"
Hello!  We recently bought this router and aim to connect our Samsung Blueray player (wireless).   Our interenet works - all of our other devices are able to connect BUT our Blueray player keeps displying the error "system time is updating, please tray again later".  After checking all of the Blueray Players settings, it seems as though it is having trouble connecting through the router.  We could really use any help you can provide!!!  Thanks.
  • Hi jenandzack,
    1. Please make sure that the Blueray player is connected to the network via wireless or wired/Ethernet.
    2. You can check with Samsung and/or the user manual on how to connect it manually.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi jenandzack,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi jenandzack,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
