jandya33
Aug 30, 2016Aspirant
My WNDR4500v3 wireless disabled.
The router's wireless stopped working and when I scanned for the SSID on my wireless devices (Smart phone and Smart TV) the SSID does not show on the list of found wireless networks. I have power cycl...
- Sep 01, 2016
I don't know why. The router is plugged into a surge protected powerstrip and we have not had a power failure for at least a year now. My Netgear range extender should still be working.
I offered to send Netgear this router for an autopsy ( or should it be necropsy? ) and I'm waiting to hear back. I spent the last ten years debugging firmware for a living so I know having broken hardware at hand makes finding the problems a lot easier. It may help some other poor soul to avoid the same problem.
The local Best Buy has a few wifi routers. I wish we had a Fry's store in Idaho. Whenever I got down to LaLa land I used to wander around that store till my credit card cried UNCLE.
Might also look into this 4K TV thing while at BB. I already know we will not be getting any curved screens.
Thanks for the info.
Jim
jandya33
I would also add thet the WIFI On Off button does nothing.
- AnonymousAug 30, 2016
try a factory default reset.....same problem.... add it to your heap
- jandya33Sep 01, 2016Aspirant
No soap. Factory default reset failed to fix anything. This is the 5th wireless router to fail on me. When the wife gets home we will go shopping for number 6.
- AnonymousSep 01, 2016
You might think about buying a small UPS too.
