Quixota
Sep 25, 2017Aspirant
My WNR2000v3 router no longer requires a password. How do I fix that?
I set up the router on my Dell PC and my iPad and iPhone. I did set up a password. After quite some time, I noticed that it was no longer secure. I can find all kinds of info on how to CHANGE a pas...
- Sep 26, 2017
Yeehaw! It let me go through those steps after I gave it the serial number again. I didn't have to tell my igadgets to forget; they went to the "new" network all by themselves. Thank you so much! I can't tell you how much better I feel.
ElaineM
Sep 26, 2017NETGEAR Employee Retired
Welcome to the community, Quixota
If you have selected any of the Security Options then you have a wireless password enabled.
Which security option have you selected?
Your devices should be asked for wireless security whenever you changed it.
I suggest that you change the wireless security and have the devices forget the connection and then reconnect it to the wireless network.
How do I change my NETGEAR router WiFi password or network name (SSID)?
Quixota
Sep 26, 2017Aspirant
Thank you! Unfortunately, I have no idea what security option I may have chosen or how to change that. Apple is also telling me to configure the router and change its name but I don't know how or where to do so. Apple does show me the option to Forget This Network. Sorry to be so ignorant but it's been quite some time since I installed this.
- ElaineMSep 26, 2017NETGEAR Employee Retired
You may follow the steps from the link that I had given and you will see the security options enabled.
