DFishrelax
Mar 05, 2021Aspirant
N 300 WIFI extender EX2700
5 months old working well, This morning found the device light wasn't on. Router, Power & WPS all Green Tried resetting but nothing works. Faulty ?
Mar 05, 2021Guru - Experienced User
The device light turns on when something is connected to it.
did you have something connected to it?
DFishrelax
The SMART TV was programmed to connect to the device. This morning the green led wasn't on and the TV said there wasn't a WIFI to connect to.
I tried everything I know, even took it back to the Router and ressting it there, but at no time did the light come on.
I've just purchassed a TP Link, set up and placed this next to the TV and everthing is working. I think it must have failed.
