psuro
Jul 11, 2022Tutor
N150 - WNR1000 v.3
I've had my router since forever, brand new. I always had it set up for ethernet and deactivated wifi. I now have devices in my home that have no ethernet capabilities and have to set my router for w...
- Jul 12, 2022
My son figured it out!!! Somehow we had switched the ethernet cables around and the cable from the modem to the router was plugged into an ethernet port. Plus he found a wifi button to push and hold on top of the router! Voila! I should have known it was something simple plus he's been a tech wiz since he was only 2 years old!
Thank you for all your responses and time. God bless you 100 fold in Jesus Name!
Jul 11, 2022Guru - Experienced User
You could always factory reset and start back over from stock.
Push and hold reset for 7-15 seconds while powered on. The lights should change.
then follow the install guide.
https://www.netgear.com/support/product/wnr1000v3
psuro
Jul 12, 2022Tutor
