TCryptid
Apr 02, 2023Aspirant
N150- WNR1000 v3 port forwarding
Need to do some port forwarding on my N150- WNR1000 v3 for one of the games on my Nintendo switch, but have no idea how I know the TCP is 80, 443 and the UDP is 3074. I have no clue what to put in for...
TCryptid
Specifically I bought a copy of Just Dance 2023 for my nintendo switch
recently in order to get the full experience it requires internet connectivity. I've had no issues connectivity to the internet on my over games however this one seems to be particularly stubborn. One of the suggested solutions is to forward ports, but nothing I've tried seems to work.
michaelkenward
Apr 02, 2023Guru - Experienced User
What happens when you try to use it? Any heplful error messages or prompts?
You are not the first person to grapple with this program:
Search - NETGEAR Communities – "Just Dance"
Did that suggestion come from the people who wrote the software?
- TCryptidApr 02, 2023AspirantAnytime I try to start up a song I get an error saying Connection Timeout disconnected from network. The suggestion to forward ports came directly from Ubisoft when I tried searching for a solution online.
- michaelkenwardApr 03, 2023Guru - Experienced User
What is the modem/gateway/ONT in front of this ancient router?
- TCryptidApr 03, 2023AspirantThe WNR1000V3 is plugged into a Comtrend VR-3030, but that's all I know.
