msu69er
May 14, 2020Tutor
N150 Wireless Router - Clearing Personal Information
I have two old routers that I no longer use. Before I recycle them I want to make sure that there is no personal information on them (network name, password, address, etc.). How do I go about clear...
- May 14, 2020
while powered on, push and hold the reset button for 7-15 seconds. The lights should flash/blink.
That'll factory reset it.
Then you can check it if you want by trying to log into it to see if it actually reset.
May 14, 2020Guru - Experienced User
