Javi3456
Nov 23, 2020Follower
N150 wnr1000v3 slow speeds
I need help with my router I get 50 mbps speed but I put the router to 150 mbps mode and doesn't work. What do I do?
> Model: WNR1000v3|Wireless Router
Firmware version? Connected to what?
> [...] I get 50 mbps speed but I put the router to 150 mbps mode and
> doesn't work. [...]How, exactly, did you "put the router to 150 mbps mode"?
Which kind of "doesn't work"? "doesn't work" at all? "doesn't work"
as fast as I expect? (And how fast is that?)> [...] What do I do?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Technical
Specifications" and "Interface Specifications". If the Ethernet
interfaces on your router are 10/100Mb/s, then you'll need a
newer/better router to get speeds higher than that.(Note: "m" = "milli" = 1/1000. "M" = "mega" = 1000000.)
- wcalifasProdigy
yea that's one of the bottom of the barrel routers that is a little old. You should upgrade to something newer to get better speeds.
