Maraian
Aug 15, 2021Aspirant
N300 cable modem router only works with short internet input cable
Modem / router only works with very short 6 ft cable. I bought a new longer cable and it won't work. This setup had been working with about 40 ft of cable and a splitter and a coupler online. Recentl...
Maraian
Aug 16, 2021Aspirant
Thanks! I checked the power of the signal via the modem login page and determined the problem was the 2 inline connectors / couplers . I previously swapped a couple of connectors to test, but they turned out to be bad also! So I just bought 2 new ones and now I'm back up and running!
Aug 16, 2021Guru - Experienced User
Glad it was an easy fix!
It might not have been that they were bad, more likely that they weren't a decent quality and were dropping the signal to much for the modem.
tough to know for sure without actual numbers off the modem with before/afters of each one.
