WiSeNhEiMeR's avatar
WiSeNhEiMeR
N300 Model WNR2000 v5 - HOW do I block a WEBSITE ?
I just purchased my  NETGEAR  N300  /  model  WNR2000 v5  WiFi Router to replace an even "older" Frontier router. I live in a very RURAL Area so I beLIEved the N300 was adequate for my  <less than...
  • plemans's avatar
    Mar 26, 2020
    I think if you disable ap mode, you're going to have issues.
    here's why.
    you might not have a modem, but you have some type of gateway with routing function in it. or only 1 of your devices would work since the netgear is in ap mode. Its own routing function has been disabled and its relying on the bridgemaxx setup for routing.
    If you disable AP mode, you'll be in a double nat due to having more than 1 routing device running on the network. This will cause you other issues.
