SteveM09's avatar
SteveM09
Follower
Nov 21, 2016
N300 WiFi Router - intermitent problem connecting my home PC to internet through router
Hi There Group,
Home PC, N300, Windows 10, nothing else fancy
I have a nagging problem.  Sometimes when I start up my PC and go to my generic home page I can see the Network Icon on the taskbar and it has a "red x".   I think it is red.  I am clor blind so this might not be correct.  It is an "x" .  When I try to bring up anything which requires internet access I am given and error messages that basically says no Internet connect avaiable.   If I turn off my PC and start over everyting is fine.  One more thing I also get a dialog box when I turn off the PC.  Something about a memory write problem.  I have ignored this in the past because I don't know what it means.  If it is important I will write it down the next time.
Thanks for any help or ideas.
Steve
  • Hi SteveM09,
    This might not be an issue with your NETGEAR equipment but rather more of an issue with your computer. You can check with the computer manufacturer to have the drivers of your LAN adapter updated and have your hard drive checked for the memory error.
    Dexter
    Community Team
1 Reply
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi SteveM09,
    Dexter
    Community Team
