mbehum
May 26, 2021Tutor
N300 Wireless Gigabit Router Slowing Internet
Hello - I get 100 MBPS Download / 5 MBPS upload through my modem (about 10 YO Arris Surfboad SB6121) -- hardwired from that to a PC I receive close to 125 down / 5.5 up When I connected a used Ne...
May 26, 2021Guru - Experienced User
the router might be 5 years for you but that device was manufactured 13 years ago. i was released in 2008.
You might try reinstalling the firmware to it in case the version its on was corrupt. A reset only clears out settings.
thats something you can try.
but it might be time to look at an upgrade for that router. Its quite far behind on technology
mbehum
May 26, 2021Tutor
I appreciate the reply and that's great perspective. That seems ancient. I will look for a new combo unit to replace this --- speed is too irregular -- I just tried another test and it got up to 46 down / 2 up on one machine, 12/1 on another, and 30/2 on a third. So ... yeah irregular. Thanks again.
- wcalifasMay 28, 2021Prodigy
Also to note, sometimes the power adapters go bad causing the router to lose wifi and connection to the modem. I have had routers have those symptoms before and when I tried a different power adapter my problems dissapeared
- plemansMay 30, 2021Guru - Experienced User
A power supply isn't a bad option to try. but if you don't have one from something else to try, I wouldn't buy one. The money would be better saved for upgrading. Again, its a bit old of a devices.
Make sure you have the exact same voltage and polarity. You can have higher amperage though
- mbehumMay 30, 2021TutorThanks all. I tried a separate power adapter. It fixed things for a few mins then back to slow. I opted to buy the Nighthawk AC1900 combo unit.
