mbehum
May 26, 2021Tutor
N300 Wireless Gigabit Router Slowing Internet
Hello - I get 100 MBPS Download / 5 MBPS upload through my modem (about 10 YO Arris Surfboad SB6121) -- hardwired from that to a PC I receive close to 125 down / 5.5 up When I connected a used Ne...
May 30, 2021Guru - Experienced User
A power supply isn't a bad option to try. but if you don't have one from something else to try, I wouldn't buy one. The money would be better saved for upgrading. Again, its a bit old of a devices.
Make sure you have the exact same voltage and polarity. You can have higher amperage though
