Kdlatsha's avatar
Kdlatsha
N300 wireless router blue light not on
My router is model WNR2000, and the blue light to confirm wireless internet will not come on. The top two lights are green and my computer has no wireless internet because the blue light is off. Can a...
  • Kdlatsha's avatar
    Kdlatsha
    May 01, 2017
    Thank you, Elaine.  Apparently, there was a setting on my computer that was not allowing the blue light to turn on, and the issue is now resolved.  Thank you for your reply.
    Kathy
