Kdlatsha
Apr 29, 2017Aspirant
N300 wireless router blue light not on
My router is model WNR2000, and the blue light to confirm wireless internet will not come on. The top two lights are green and my computer has no wireless internet because the blue light is off. Can a...
- May 01, 2017
Thank you, Elaine. Apparently, there was a setting on my computer that was not allowing the blue light to turn on, and the issue is now resolved. Thank you for your reply.
Kathy
ElaineM
May 01, 2017NETGEAR Employee Retired
Welcome to the community, @2Kdlatsha
Did you try to factory reset the router?
If you did and still the wireless light is not lit then consider the unit faulty.
Check if you can still replace it if it's within the hardware warranty.
Kdlatsha
May 01, 2017Aspirant
Kathy
- ElaineMMay 02, 2017NETGEAR Employee Retired
Can you share what kind of setting is that in order for others to benefit from it too?
- KdlatshaMay 02, 2017Aspirant
I am sorry, but I do not remember what the setting was. I was looking at different areas of my computer regarding internet connections and noticed that a box was not checked. When I checked the box, the blue light on my router came on. I am sorry that I can't be more helpful.
Thank you for the update. Glad that it's working now.
