Kdlatsha
Apr 29, 2017Aspirant
N300 wireless router blue light not on
My router is model WNR2000, and the blue light to confirm wireless internet will not come on. The top two lights are green and my computer has no wireless internet because the blue light is off. Can a...
- May 01, 2017
Thank you, Elaine. Apparently, there was a setting on my computer that was not allowing the blue light to turn on, and the issue is now resolved. Thank you for your reply.
Kathy
Kdlatsha
May 01, 2017Aspirant
Kathy
ElaineM
May 02, 2017NETGEAR Employee Retired
Can you share what kind of setting is that in order for others to benefit from it too?
- KdlatshaMay 02, 2017Aspirant
I am sorry, but I do not remember what the setting was. I was looking at different areas of my computer regarding internet connections and noticed that a box was not checked. When I checked the box, the blue light on my router came on. I am sorry that I can't be more helpful.
- ElaineMMay 02, 2017NETGEAR Employee Retired
Thank you for the update. Glad that it's working now.
