Harrisonuzurv
Jan 22, 2021Aspirant
N300 Wireless Router error connecting devices
Cable Internet from Motorola modem is flowing correctly. Please see attached photos to rule out modem issues. Purchased this netgear N300 wireless router used from a friend. Its network name is netgea...
Jan 22, 2021Guru - Experienced User
Any used devices should be factory reset and setup from factory.
Have you tried this?
Push and hold reset for 7-15 seconds while its powered on. Then simply follow the install guide found here:
https://www.netgear.com/support/product/WNR3500Lv2.aspx
- HarrisonuzurvFeb 06, 2021Aspirant
Plemans - I really appreciate your time trying to help me troubleshoot. I did as you suggested and took a bobby pin to hold down the "Restore Settings" button in red for 10-15 seconds on the back of the router. This was before I connected it to the modem.
So then once I connected to the modem, I can see NETGEAR74 appear on my macbook air network options. I connect to it on top right of my screen (in the airport) then a netgear window pops up. After 90 seconds of testing the connection, it asks me "Do you want the Genie to help connect you?" If I click No, nothing happens, as if the button doesn't work. When I click yes - it goes through the images below ... and after 2 minutes of "checking" and "pending" it gives up, and disconnects me from NETGEAR74. Tries to find a new network at that point. Yet all of the lights on both the modem and the router look correct, as if all information is flowing smoothly. Please see screenshots & the original photo of the router + modem.- HarrisonuzurvFeb 06, 2021Aspirant
Hmmm ... looks like the screenshots weren't coming through when I checke the post. Trying a different way.
Photo of Netgear Genie asking Yes or No
Genie checking for internet connection ... 60 seconds here ...
