Paullane
Jan 05, 2017Aspirant
N300 wireless router not working after power down
I powered the router and all equipment down for 2 wks, when I powered everything back on the router did not work wireless or hardware from it. A hardwire from the modem works so the connection is the...
- Jan 13, 2017
Gave up and bought a new piece of equipment
michaelkenward
Jan 06, 2017Guru - Experienced User
Remember, it is important to turn things on in the right order.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
This is so that each bit knows who is in charge.
Paullane
Jan 06, 2017Aspirant
I have tried this power sequence and it doesn't work do you have another suggestion
- StephenBJan 06, 2017Guru - Experienced User
After the router powers up, is the internet light lit on the front of the router? It should be under the power light and above the wifi light.
If it is lit, what color is it?
- PaullaneJan 06, 2017Aspirant
yes it is on but it is Yellow
- michaelkenwardJan 07, 2017Guru - Experienced User
Have you been through the setup process from fresh.
Can you login to the interface of the WNR2000?
http://www.routerlogin.com/
or
http://www.routerlogin.net
Have you checked the settings for your ISP login?See page 1-7 of the manual:
WNR2000v1 | Product | Support | NETGEAR
See page 7-6 for troubleshooting the "amber light" issue.
