Paullane
Jan 06, 2017Aspirant
N300 wireless router not working after power down
I powered the router and all equipment down for 2 wks, when I powered everything back on the router did not work wireless or hardware from it. A hardwire from the modem works so the connection is the...
- Jan 13, 2017
Gave up and bought a new piece of equipment
Paullane
yes it is on but it is Yellow
michaelkenward
Jan 07, 2017Guru - Experienced User
Have you been through the setup process from fresh.
Can you login to the interface of the WNR2000?
http://www.routerlogin.com/
or
http://www.routerlogin.net
Have you checked the settings for your ISP login?
See page 1-7 of the manual:
WNR2000v1 | Product | Support | NETGEAR
See page 7-6 for troubleshooting the "amber light" issue.
