Mangroves08
Jul 16, 2023Aspirant
N300 Wireless Router WNR2000v3 update firmware possible?
I'm tech challenged. Bought the router in 2012. Never updated it (didn't know i have to). Is it possible to update the firmware to the latest version supported and it so, how do i find the download...
Mangroves08
Jul 17, 2023Aspirant
Hi Michael. Thanks for taking the time to respond. Do I need to get an Ethernet cable or can I do the download and update of modem wirelessly?
michaelkenward
Jul 18, 2023Guru - Experienced User
gui\
An Ethernet cable is always useful when working on a router. That's why Netgear supplies one with its routers.
You can update firmware over wifi, but that can be risky. If the wifi falls over in the process, you can wreck your device.
It will also depend on what you plan to use for the wifi. This is not something I would do with a phone. But if it is a laptop, then you can use that to get at routerlogin.net:
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
- Mangroves08Jul 18, 2023AspirantThanks. What about the security of this router? Do you recommend buying a new one? We don’t do any gaming. Just watch videos on social media.
- michaelkenwardJul 18, 2023Guru - Experienced User
I have no idea about the security, but your router is pretty old and won't support some of the newer wifi security standards.
How fast is your Internet service? The WNR2000v3 is no good for anything faster than 100 Mbps.
