cssva3
Feb 08, 2016Aspirant
N300 Wireless Router WNR2000v4 slowing download speeds
Hello, I have Time Warner Cable and pay for 50mps download speed. When connected directly to the Modem I get better than 50mps download. When I run through the Wireless router using either wire...
ElaineM
Feb 09, 2016NETGEAR Employee Retired
Hi cssva3 Do you have the latest firmware installed on your router?
If not, see this link on how to upgrade the firmware.
After firmware upgrade, reset the router by pressing the reset button for 20 seconds.
Once done, reconfigure the router to get the Internet connection back.
Retired_Member
Feb 09, 2016Is this a new problem? Did it ever work?
- cssva3Feb 09, 2016Aspirant
Hello searay, No it has never worked as far as I know. I just resently upgraded to the 50mps service so I was checking.
- Retired_MemberFeb 10, 2016Update the firmware as already suggested and factory reset it after, try using another cable between modem and router
