Wurlinx
Jun 21, 2022Tutor
n300 wnr2000v5 wifi router firmware latest version
N300 WNR2000v5 1.0.0.78 Spectrum
- Jun 22, 2022
You are on the latest version.
As michaelkenward says, are you having an issue?
Jun 22, 2022Guru - Experienced User
Wurlinx
Jul 10, 2022Tutor
Thanks for the response. No, just wanting to make sure I'm up to date.
- plemansJul 11, 2022Guru - Experienced User
Glad you're not having issues and was just checking firmware.
You might mark it solved so others aren't trying to fix an issue thats not an issue.
Thanks!
Let us know if you do have issues.
