Wurlinx
Jun 21, 2022Tutor
n300 wnr2000v5 wifi router firmware latest version
N300 WNR2000v5 1.0.0.78 Spectrum
- Jun 22, 2022
You are on the latest version.
As michaelkenward says, are you having an issue?
Jun 22, 2022Guru - Experienced User
Wurlinx
Jul 15, 2022Tutor
Actually, I do have an issue; but because my firmware question was answered I moved on. However, the additional problem I had was and still is that I cant log into my Admin account/ Genie or whatever that window is called. Before now, I could log into that account( Admin) by using routerlogin.net; but lately even though I use that URL, it only allows me to login with my email address/username. It does not give me the Admin login window at all. So I'm unable to access my router info or make any Advance changes I want to.
Any recommendations would be appreciated.
Thanks
- plemansJul 15, 2022Guru - Experienced User
Try using its ip address and not the routerlogin option
- michaelkenwardJul 15, 2022Guru - Experienced User
Wurlinx wrote:
... I cant log into my Admin account/ Genie or whatever that window is called.Whatever that window is could be important.
How are trying to logon? Wired? Wifi? Browser? Mobile App? Desktop program?
....even though I use that URL, it only allows me to login with my email address/username.That's not normal. If it asks for an email address you need to work out why.
But there are lots of different login options. (See above.)
What are you doing and where does it go wrong?
The devil – and solution – is in the details.
- WurlinxJul 24, 2022Tutor
michaelkenward For a minute I thought you were mocking me. Then I looked at the last sentence...'the devil - and solution - is in the details.'
I let that sunk in and then respond accordingly. The solution is indeed in the details.
Thank You
