Wurlinx
Jun 21, 2022Tutor
n300 wnr2000v5 wifi router firmware latest version
N300 WNR2000v5 1.0.0.78 Spectrum
- Jun 22, 2022
You are on the latest version.
As michaelkenward says, are you having an issue?
Wurlinx
Jul 15, 2022Tutor
Actually, I do have an issue; but because my firmware question was answered I moved on. However, the additional problem I had was and still is that I cant log into my Admin account/ Genie or whatever that window is called. Before now, I could log into that account( Admin) by using routerlogin.net; but lately even though I use that URL, it only allows me to login with my email address/username. It does not give me the Admin login window at all. So I'm unable to access my router info or make any Advance changes I want to.
Any recommendations would be appreciated.
Thanks
Jul 15, 2022Guru - Experienced User
Try using its ip address and not the routerlogin option
