takussaagut
Oct 30, 2022Aspirant
N300 WNR2000v5
I have manually reset routher, and now I am in this with my browser 10.0.10.1 it asks for user+pass As it's already done reset (with a needle) , user name suppose to be: admin adn the pass: pas...
- Oct 30, 2022
You have some sort of problem with a WNR2000v5? What is it?
That suggests that you have something else on your network that is also working as a router.
By default it would have an address more like 192.168.1.1
What di you mean buy this?
, user name suppose to be: admin adn the pass: password but those doesn't work.Doesn't work in what sense?
What are you doing?
Where are you feeding in this username and password?
What happens when you try it?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
michaelkenward
Oct 30, 2022Guru - Experienced User
What are you doing?
Support | NETGEAR
