Needleroozer
Nov 17, 2017Aspirant
N300 WNR3500Lv2 Fast LAN, Slow WiFi - with a twist
N300 router with latest firmware, Arris SB6141 cable modem. Modem dies, replaced with an SB6183. But the N300 couldn't talk to the SB6183, couldn't get an IP address. So at the suggestion of the Comc...
- Nov 20, 2017
Well, I solved my problem. I switched to a D-Link router and now everything's fine.
Needleroozer
Nov 18, 2017Aspirant
Ah ha! A clue! Comcast speed test lets you choose IPv4 or IPv6. IPv4 is fast, IPv6 is as slow as the speedtest.net tests. So, how am I _supposed_ to configure IPv6, because clearly the router reset defaults aren't working.
- michaelkenwardNov 18, 2017Guru - Experienced User
Find out which type of IPv6 Comcast uses and see if you can set your WNR3500Lv2 to that.
There is a manual for the WNR3500Lv2 somewhere at the end of this link:
>>>> WNR3500Lv2 | Product | Support | NETGEAR <<<<
See page 91.
- NeedleroozerNov 18, 2017Aspirant
After trying the entire list, the last setting - "Auto Config" - worked for Comcast's speed test. It's now 50-60 Mbps for either IPv4 or IPv6.
speedtest.net is still below 1 Mbps, and the internet in general feels slow, so it's more than just speedtest.net. But, again, why is some WiFi fast and other WiFi dead slow?
- NeedleroozerNov 20, 2017Aspirant
