davidaccola
Feb 07, 2021Aspirant
N600 - How to reenable Router Mode?
I have followed the documentation here to enable modem-only mode on my N600 router/modem: https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only That documentation sh...
- Feb 07, 2021
That's really good info, thank you... I navigated to 192.168.100.1 and the web interface does load up, but not fully (not enough to be able to reverse the process). Is this a known issue?
What I get is an eternal loading wheel where the 'Router modem' setting ought to be. The browser dev console (Ctrl+Shift+I) reveals some errors--don't know if those are directly releated or not.
Edit: If anyone else encountering this same issue runs across this thread, it looks like the specific frame that isn't loading up is called http://192.168.100.1/RouterMode.htm - I'm not going to try it right now, but hypothetically navigating directly to that frame and then making the change would work even when the web interface overall is acting a bit broken.
davidaccola
Feb 08, 2021Guru - Experienced User
Try using a different browser and/or pc.
Sometimes clearing cookies/cache can help as well.
