6Aussies
Jan 16, 2020Aspirant
N600 access
I currently have a R6300v2 router running my network. I have a N600 WNDR3400 that I'm trying to configure. I have the R3400 hooked to my laptop with a CAT5 cable however when I got to http://www.rout...
- Jan 18, 2020
You are correct. Cat5 cable from my laptop needs to go to LAN not WAN connection on router. Once I switch connections I was able to access the WNDR3400 with no problem. thanks for your patience and help.
antinode
Jan 17, 2020Guru
> [...] (V1 I'm guessing since the label just says WNDR3400 with no
> version number. [...]
Yup.
> Firmware version? v1.0.3.6_1.0.63CH
That looks like an ISP-specific (Charter) version. Atypical, but
shouldn't be a problem.
> I have the WNDR3400 hooked to my laptop with a CAT5 cable (from the WAN
> connector on the WNDR3400 to the ethernet connection on my laptop.
> Laptop is on the Genie R6300v2 network and recognizes the LAN connection
> from the WNDR3400) [...]
At least one of us is confused. Any WNDR3400 client devices should
be connected to the LAN ports of the WNDR3400. The WAN/Internet port
(if it's used at all) would be connected to something closer to your
ISP. That would explain why you can't get to the WNDR3400 management
web site from your laptop -- the WNDR3400 would see that as "Remote
Management", which uses a different URL, and is disabled by default. If
you connect the laptop to a _LAN_ port on the WNDR3400, then you might
get further.
And how is the WNDR3400 connected to the R6300v2?
> [...] I'm trying to configure (as a wireless access point [...]
That should be possible, but, as threatened, the "v1" might make it
messy. I'd fetch the WNDR3400v2 User Manual to see the easy way -- Look
for "AP Mode" -- and verify that you don't have that option on your
"v1". Assuming that you don't, then you should be able to use the
step-by-step at:
https://community.netgear.com/t5/x/x/m-p/1463500
That's written for a C6300-as-WAP, but the steps are about the same for
any other router (any make/model) which lacks a one-step WAP option.
Note that that scheme leaves the WNDR3400 WAN/Internet port unconnected.
(A WAP is all-LAN. A model with the one-step WAP option effectively
reconfigures its WAN/Internet port as another LAN port. Without the
one-step WAP option, you need to use only the LAN ports.)
6Aussies
Jan 18, 2020Aspirant
