Norman2000
Jun 13, 2021Follower
N600 as a Wifi extender
I have WNDR3400v3 N600, and i would like to connneted to my new Netgear AC1600 R6260 to work as a Wifi extender to cover the 2nd floor, i tried to connect it via the WPS but it didnt worked, So pleas...
Jun 13, 2021Guru - Experienced User
I don't see in the manual anywhere that the WNDR3400v3 supports repeater/extender mode.
You could hardwire it in and use as an access point.
michaelkenward
Jun 14, 2021Guru - Experienced User
Oh so true. Perhaps Norman2000 should check the manual.
Visit the support pages:
Support | NETGEAR
Feed in the model number and check the documentation for the hardware.
Norman2000 may have done that already. I can't tell from their message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
