tymyphotos
Mar 17, 2017Follower
N600 C3400 wndr3400v2 Wifi Speeds Slow
Unfortunately, after reading so many threads on this model, I'm not sure there is a fix. I recently upgraded my comcast internet to Blast!. Unfortunately with this router I'm not seeing an incre...
- Aug 02, 2017
You were right. Bought an AC router and speeds are correct. Thanks.
ElaineM
Mar 18, 2017NETGEAR Employee Retired
Welcome to the community, tymyphotos
First off, to which device you are connected? Are both wireless signals turned on, on the cable gateway and router?
Secondly, what's the wireless adapter used?
Wired connection speed will always be different from the wireless speed.
Improving 2.4Ghz Wireless Performance by Changing Channel
