jayinva
Apr 23, 2017Aspirant
N600 cannot connect to wifi devices
firmware V1.0.1.8 my cell is unable to connect to the internet via wifi. my cell searches for a signal by showing "Connecting", but never connects and says either "authentication error occurred"...
- Apr 26, 2017
WNDR3400V3
IT WORKED!!! the factory reset did the trick!
Thanks to michaelkenward and ElaineM!!!
J
michaelkenward
Apr 24, 2017Guru - Experienced User
Which modem/router is this?
N600 is not a model number. It is a wifi standard. Many companies make N600 devices. Netgear alone has dozens of modems, routers and wifi widgets that are N600.
Can you see the SSID? Have you configured the wifi security?
If this just started, have you rebooted the device?
jayinva
Apr 24, 2017Aspirant
I have a Netgear WNDR3400v3 firmware V1.0.1.8
Yes, I can see the SSID
When i bought the router in Dec 2013, i read up on how to configure the security settings and set them accordingly and have not changed them since.
The security option i chose is: WPA2-PSK
Yes i have rebooted the router several times
Thanks in advance for your help!!
J
- michaelkenwardApr 25, 2017Guru - Experienced User
Your firmware is up to date.
If it is just your phone that cannot connect, maybe you should investigate that as the source of the problem. As the saying goes, it takes two to tango.
Tell the phone to forget past connections to your WNDR3400v3 and start from scratch.
The manual for your router is here:
>>> WNDR3400v3 | Product | Support | NETGEAR <<<
If nothing else works you could reset the router to its factory settings. You could make the process easier by saving its settings and restoring them after the reset.
Good luck.
- jayinvaApr 25, 2017Aspirant
netgear WNDR3400v3
3 devices will not connect, 2 cells and a Roku
I tried about everything under the sun and about ready to purchase a new one, beacuse I don't have much hair left.
does this mean anything to you...
somewhere i read to try and connect by using no security, an "open" connection. well i tried this(very briefly) and it worked, i was able to connect via wifi on my cell. does this mean the router is ok, but the security settings need adjustment, and if so how should i do that? what do you think i should do?
thanks
J
- ElaineMApr 26, 2017NETGEAR Employee Retired
jayinva The router seems to be working, try to factory reset it and then reconfigure the settings.
