jayinva
Apr 23, 2017Aspirant
N600 cannot connect to wifi devices
firmware V1.0.1.8 my cell is unable to connect to the internet via wifi. my cell searches for a signal by showing "Connecting", but never connects and says either "authentication error occurred"...
- Apr 26, 2017
WNDR3400V3
IT WORKED!!! the factory reset did the trick!
Thanks to michaelkenward and ElaineM!!!
J
ElaineM
Apr 26, 2017NETGEAR Employee Retired
jayinva The router seems to be working, try to factory reset it and then reconfigure the settings.
