epags1
Jan 21, 2023Aspirant
N600 DSN address cannot be found
Today lost all wireless internet connections to laptops, android tablets and 'smart' TV The two desktop computers hardwired to the modem have internet connection. The subject router lights all app...
- Jan 22, 2023
epags1 wrote:
However I bought a NETGEAR AC1900 as a replacement and in setting it up, found an access to the ARRIS controls and could see the conflicting network names (SSID).
That is a sign that your "modem" also delivers wifi. So it isn't just a modem.
For a more manageable network and to reduce the risk of future hassles, look into putting the ARRIS thing into modem only (bridge) mode.
arris dg1670a bridge mode - Google Search
Plenty to choose from there.
michaelkenward
Jan 21, 2023Guru - Experienced User
Which "N600" are we talking about?
N600 not a Netgear model number. It is a label on many devices with ancient (pre 2010) WiFi technology.
Or is the router ready to be replaced?
Given the age of the device, that might not be a bad idea. You will certainly get better wifi technology. Does it even support 5 GHz? Some N600s don't, they are that old.
