epags1
Jan 21, 2023Aspirant
N600 DSN address cannot be found
Today lost all wireless internet connections to laptops, android tablets and 'smart' TV The two desktop computers hardwired to the modem have internet connection. The subject router lights all app...
- Jan 22, 2023
epags1 wrote:
However I bought a NETGEAR AC1900 as a replacement and in setting it up, found an access to the ARRIS controls and could see the conflicting network names (SSID).
That is a sign that your "modem" also delivers wifi. So it isn't just a modem.
For a more manageable network and to reduce the risk of future hassles, look into putting the ARRIS thing into modem only (bridge) mode.
arris dg1670a bridge mode - Google Search
Plenty to choose from there.
epags1
Thought it was included.....model WNDR3400v3
- michaelkenwardJan 22, 2023Guru - Experienced User
Not that I can see.
By the way, it looks like your ARRIS DG1670 "modem" may be a modem/router or "gateway". So you are trying to use two routers on your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. But some Internet service providers, such as BT in the UK, supply modem/routers that won't work in bridge mode. There may be ways to get the modem/router to cooperate. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support- epags1Jan 22, 2023Aspirant
Years ago the modem was supplied by Spectrum without documentation and I ASSUMED it was a normal modum. The N600 router had been hooked up since 2019 without any issue. The problem just started. Reason unknown...probably a modem hardware upgrade.
However I bought a NETGEAR AC1900 as a replacement and in setting it up, found an access to the ARRIS controls and could see the conflicting network names (SSID). Interestingly enough the network keys were the same. Yesterday I managed to get the 2.4Ghz wireless band working and will be working to reset the 5Ghz band today.
Thanks all you forum NETGEAR experts for the help. I am a retired civil engineer (83 years old) and the changes in computer technology are coming faster than I can keep up.
