epags1
Jan 21, 2023Aspirant
N600 DSN address cannot be found
Today lost all wireless internet connections to laptops, android tablets and 'smart' TV The two desktop computers hardwired to the modem have internet connection. The subject router lights all app...
- Jan 22, 2023
epags1 wrote:
However I bought a NETGEAR AC1900 as a replacement and in setting it up, found an access to the ARRIS controls and could see the conflicting network names (SSID).
That is a sign that your "modem" also delivers wifi. So it isn't just a modem.
For a more manageable network and to reduce the risk of future hassles, look into putting the ARRIS thing into modem only (bridge) mode.
arris dg1670a bridge mode - Google Search
Plenty to choose from there.
epags1
Jan 22, 2023Aspirant
Years ago the modem was supplied by Spectrum without documentation and I ASSUMED it was a normal modum. The N600 router had been hooked up since 2019 without any issue. The problem just started. Reason unknown...probably a modem hardware upgrade.
However I bought a NETGEAR AC1900 as a replacement and in setting it up, found an access to the ARRIS controls and could see the conflicting network names (SSID). Interestingly enough the network keys were the same. Yesterday I managed to get the 2.4Ghz wireless band working and will be working to reset the 5Ghz band today.
Thanks all you forum NETGEAR experts for the help. I am a retired civil engineer (83 years old) and the changes in computer technology are coming faster than I can keep up.
michaelkenward
Jan 22, 2023Guru - Experienced User
