n33tzsche
Mar 13, 2018Aspirant
N600 Dual Band Router NAT type strict on PS4 issues
I have seen a few posts about this but not much resolution. I have the N600 WiFi Dual Band Router. I am able to play sometimes with friends on my PS4, however, cannot communicate in parties via heads...
- Apr 02, 2018
Hi n33tzsche,
1. Please make sure you have done DMZ and Port Forwarding separately and not simultaneously.
2. Some suggested ports to forward are:
- 80
- 443
- 465
- 983
- 3478-3480
- 3658
- 5223
- 6000-7000
- 9293
- 10070-10080
3. Also, DMZ is not recommended and is usually done for isolation.
Dexter
Community Team
DexterJB
Mar 20, 2018NETGEAR Moderator
Hi n33tzsche,
1. What is the firmware version of the router?
2. Is the router connected to a wall patch from the main apartment complex router?
3. Have you tried bypassing the router (connecting straight to the wall patch)?
4. If the issue persists without your router involved, the restriction may possibly be from the main router from the apartment complex.
Dexter
Community Team
DexterJB
Mar 25, 2018NETGEAR Moderator
Hi n33tzsche,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- DexterJBApr 02, 2018NETGEAR Moderator
Hi n33tzsche,
- 80
- 443
- 465
- 983
- 3478-3480
- 3658
- 5223
- 6000-7000
- 9293
- 10070-10080
Dexter
Community Team
