zehnaxis's avatar
zehnaxis
N600 local network blocked
To start this router has been installed and working for 6 months maybe more a friend bought a new laptop ask me to help setup his printer wireless so he can print from his laptop. his desktop PC i...
  • zehnaxis's avatar
    zehnaxis
    Jul 18, 2017
    The solution was turn off Wireless Isolation setting in the router. I found this out later and thought I should share the solution ..in this case not olny does this feature block commutation to just wired units but also to all IP address connected to the router.
