Saddie
Oct 22, 2023Aspirant
N600 speed
I have 500 mb on my Wi-Fi, so will my router and modem N600 handle the 5OO or do I need a bigger router and modem??
microchip8
Oct 22, 2023Master
N600 is an ancient router and many generations behind, so no, it won't handle. You did not say what your modem is.
(PS: N300 is a speed, not router model)
- SaddieOct 23, 2023AspirantI have a modern and router built in one, it’s a N600 802.11 dual band gigabit, built in DOCSIS 3.0 cable modem….. so if this won’t hold speed of 500 mbps then want to you recommend that’s not to expensive, I want a dual band. Thanks
- microchip8Oct 23, 2023MasterI'm not sure about which model you're talking. At first I thought your N600 is the WNDR3400 model. Now you say it also has a modem which makes it a Gateway. Again, N600 is a speed *not* modem or router model. Look underneath on the label which is says Model.
That said, if the modem is docsis 3.0, it can handle 500 Mbps. I do not know about the router part since, as I said, I don't know your device's model.- SaddieOct 23, 2023AspirantIt’s a Netgear N600 WI-FI cable modem and router…. (Dual band 300t300) range…it saids cable modem speed up to 340 Mbps… 8 x 4 channeling bonding
