Saddie
Oct 22, 2023Aspirant
N600 speed
I have 500 mb on my Wi-Fi, so will my router and modem N600 handle the 5OO or do I need a bigger router and modem??
microchip8
Oct 22, 2023Master
N600 is an ancient router and many generations behind, so no, it won't handle. You did not say what your modem is.
(PS: N300 is a speed, not router model)
Saddie
Oct 23, 2023Aspirant
I have a modern and router built in one, it’s a N600 802.11 dual band gigabit, built in DOCSIS 3.0 cable modem….. so if this won’t hold speed of 500 mbps then want to you recommend that’s not to expensive, I want a dual band. Thanks
- microchip8Oct 23, 2023MasterI'm not sure about which model you're talking. At first I thought your N600 is the WNDR3400 model. Now you say it also has a modem which makes it a Gateway. Again, N600 is a speed *not* modem or router model. Look underneath on the label which is says Model.
That said, if the modem is docsis 3.0, it can handle 500 Mbps. I do not know about the router part since, as I said, I don't know your device's model.- SaddieOct 23, 2023AspirantIt’s a Netgear N600 WI-FI cable modem and router…. (Dual band 300t300) range…it saids cable modem speed up to 340 Mbps… 8 x 4 channeling bonding
- microchip8Oct 23, 2023MasterWell, if it says that, then no, it can't handle the speed you ask about. It's too old. Time to catch up to current technology 🙂
- michaelkenwardOct 23, 2023Guru - Experienced User
Saddie wrote:
I want a dual band.To do what?
There is a chance that you can keep the modem/router and put it into bridge (modem only) mode.
microchip8 wrote:
That said, if the modem is docsis 3.0, it can handle 500 Mbps. I do not know about the router part since, as I said, I don't know your device's model.That is the key question. Without that detail, no one can tell you what you could do with your modem/router.
Netgear has made several cable modem/routers over the years. For example, one N600 device is the C3700. This has a Gigabit Ethernet connection that runs at 1000 Mbps, so it can feed a new router that runs at that speed.
To see if you can add a router to your modem/router, check the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Look for a the section in the manual Cable Your Modem Router to a Router.If you decide to replace the modem, most experienced users would suggest buying a separate modem and router. In that way you can replace the router bit should you ever want an even flashier wifi setup.
