Saddie
Oct 22, 2023Aspirant
N600 speed
I have 500 mb on my Wi-Fi, so will my router and modem N600 handle the 5OO or do I need a bigger router and modem??
Saddie
Oct 23, 2023Aspirant
I have a modern and router built in one, it’s a N600 802.11 dual band gigabit, built in DOCSIS 3.0 cable modem….. so if this won’t hold speed of 500 mbps then want to you recommend that’s not to expensive, I want a dual band. Thanks
microchip8
Oct 23, 2023Master
I'm not sure about which model you're talking. At first I thought your N600 is the WNDR3400 model. Now you say it also has a modem which makes it a Gateway. Again, N600 is a speed *not* modem or router model. Look underneath on the label which is says Model.
That said, if the modem is docsis 3.0, it can handle 500 Mbps. I do not know about the router part since, as I said, I don't know your device's model.
- SaddieOct 23, 2023AspirantIt’s a Netgear N600 WI-FI cable modem and router…. (Dual band 300t300) range…it saids cable modem speed up to 340 Mbps… 8 x 4 channeling bonding
- microchip8Oct 23, 2023MasterWell, if it says that, then no, it can't handle the speed you ask about. It's too old. Time to catch up to current technology 🙂
- plemansOct 23, 2023Guru - Experienced User
do you have the C3700?
Its a pretty old/slow device.
If you're paying for 500mbps, I'd look at upgrading to one of the current generation AX devices with a docsis 3.1 modem.
If you're looking for a combo (modem/router) device, I'd look at the CAX30 or CAX80
I personally prefer the modem separate from the router so you can upgrade independently.
- michaelkenwardOct 23, 2023Guru - Experienced User
Saddie wrote:
It’s a Netgear N600 WI-FI cable modem and router….Again. That is not a model number in Netgear's range.
Is it out of reach where you can't look for a label on the bottom?
Saddie wrote:
I want a dual band.To do what?
There is a chance that you can keep the modem/router and put it into bridge (modem only) mode.
microchip8 wrote:
That said, if the modem is docsis 3.0, it can handle 500 Mbps. I do not know about the router part since, as I said, I don't know your device's model.That is the key question. Without that detail, no one can tell you what you could do with your modem/router.
Netgear has made several cable modem/routers over the years. For example, one N600 device is the C3700. This has a Gigabit Ethernet connection that runs at 1000 Mbps, so it can feed a new router that runs at that speed.
To see if you can add a router to your modem/router, check the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Look for a the section in the manual Cable Your Modem Router to a Router.If you decide to replace the modem, most experienced users would suggest buying a separate modem and router. In that way you can replace the router bit should you ever want an even flashier wifi setup.
