Saddie
Oct 22, 2023Aspirant
N600 speed
I have 500 mb on my Wi-Fi, so will my router and modem N600 handle the 5OO or do I need a bigger router and modem??
Saddie
Oct 23, 2023Aspirant
It’s a Netgear N600 WI-FI cable modem and router…. (Dual band 300t300) range…it saids cable modem speed up to 340 Mbps… 8 x 4 channeling bonding
microchip8
Oct 23, 2023Master
Well, if it says that, then no, it can't handle the speed you ask about. It's too old. Time to catch up to current technology 🙂
- plemansOct 23, 2023Guru - Experienced User
do you have the C3700?
Its a pretty old/slow device.
If you're paying for 500mbps, I'd look at upgrading to one of the current generation AX devices with a docsis 3.1 modem.
If you're looking for a combo (modem/router) device, I'd look at the CAX30 or CAX80
I personally prefer the modem separate from the router so you can upgrade independently.
