DanH3's avatar
DanH3
N600 Time Warner Issue
Hello! I bought and have used my N600 with Comcast over the last year in Chicago with no problems. I moved to Dallas yesterday, and attempted to get my internet set up. Hooked everything up, called...
  • DanH3's avatar
    DanH3
    Aug 09, 2015
    We had previously tried doing a factory reset, but that didn't work.
    But I have a update - the Time Warner Cable modem/router came, I plugged it in called TWC, they activated it, I was able to connect to the internet, I plugged in the N600, and then asked them to verify the MAC address, it took a few minutes but started working.
    Perhaps it was a MAC address issue, but I think there was something that they activated on their end.
    Thanks for your help!
