DanH3
Aug 01, 2015Aspirant
N600 Time Warner Issue
Hello! I bought and have used my N600 with Comcast over the last year in Chicago with no problems. I moved to Dallas yesterday, and attempted to get my internet set up. Hooked everything up, called...
- Aug 09, 2015
We had previously tried doing a factory reset, but that didn't work.
But I have a update - the Time Warner Cable modem/router came, I plugged it in called TWC, they activated it, I was able to connect to the internet, I plugged in the N600, and then asked them to verify the MAC address, it took a few minutes but started working.
Perhaps it was a MAC address issue, but I think there was something that they activated on their end.
Thanks for your help!
netwrks
Aug 05, 2015Master
If this is your device "N600 Wireless Dual Band Router WNDR3400" then it is just a router.. router pic
I was asking you of you could plug into the TWC MODEM with an ethernet cable with a laptop?
DanH3
Aug 05, 2015Aspirant
No, it is not just a router. I have a NETGEAR N600 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3700).
Here is a link to my modem router: http://www.amazon.com/dp/B00IF0JAYE/ref=pe_385040_121528360_TE_dp_1
Thanks for your continued support to help me resolve this.
- netwrksAug 06, 2015Master
If you have not already done so, I would reflash the router and go throught the connection Wizard. Failing all these steps, I would reconfirm with you ISP that they entered the correct MAC address for your router..
- DanH3Aug 09, 2015Aspirant
