DanH3
Aug 01, 2015Aspirant
N600 Time Warner Issue
Hello! I bought and have used my N600 with Comcast over the last year in Chicago with no problems. I moved to Dallas yesterday, and attempted to get my internet set up. Hooked everything up, called...
- Aug 09, 2015
We had previously tried doing a factory reset, but that didn't work.
But I have a update - the Time Warner Cable modem/router came, I plugged it in called TWC, they activated it, I was able to connect to the internet, I plugged in the N600, and then asked them to verify the MAC address, it took a few minutes but started working.
Perhaps it was a MAC address issue, but I think there was something that they activated on their end.
Thanks for your help!
netwrks
Aug 06, 2015Master
If you have not already done so, I would reflash the router and go throught the connection Wizard. Failing all these steps, I would reconfirm with you ISP that they entered the correct MAC address for your router..
DanH3
Aug 09, 2015Aspirant
