bpye4611
Aug 24, 2015Aspirant
N600 Windows 10 installer error 1618 - installation in progress
My N600 installation fails when using the downloaded Windows 10 installer with Windows Installer error 1618, another installation running. There is no other installation running. The Event Manager reports the installation was successful. How do I fix this? Is it a Windows problem or a NetGear problem?
It was a Windows problem. I ran Task manager and found a 32-bit installer app running from a week ago, deleted it, re-ran the N600 installation and after it cleaned-up leftover installer files, the N600 installation completed. What's odd is that I had rebooted the laptop several times yet the old installer was still active.
1 Reply
- bpye4611Aspirant
