nanc1234
May 14, 2021Aspirant
N600 wireless dial band router WNDR3400-100NAS
Ten yr old router. How do I get it to work without plugging into Verizon router pls? Thx.
antinode
May 14, 2021Guru
> [...] How do I get it to work [...]
Define "work"? What, exactly, would you like it to do?
> [...] without plugging into Verizon router pls? [...]
Did you expect the WNDR3400 to access the Internet with no connection
to the Internet?
- nanc1234May 14, 2021AspirantI need modem correct ? Yes was expecting router to access internet
- antinodeMay 14, 2021Guru
If you want an Internet connection, then you need an Internet
connection. That usually means an ISP. The service from some ISPs
requires a modem.> [...] without plugging into Verizon router pls? [...]
Do you already have a "Verizon router"?
Is there some actual problem which you are trying to solve? I don't
understand what you're trying to do.
